Activity Forums Apple Final Cut Pro Legacy how to skip VST audio plugins in FCP
  • how to skip VST audio plugins in FCP
    Posted by Andre Luis on April 26, 2008 at 12:26 pm
    Hi folks. My FCP 6 insists to search all the audio VST plugins I have in the library/audio/plugins/vst folder when it starts. I use these plugins for ableton live only and I don’t need FCP losing time to search for them at every start up. How do I do to make FCP “skip” them? Thanks!
    Arya Boustani replied 12 years, 11 months ago 4 Members · 3 Replies
  • Jerry Hofmann
    April 26, 2008 at 9:40 pm
    Take them out of the folder they’re in? No way otherwise don’t think.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Andy Mees
    April 27, 2008 at 3:40 am
    I think Jerry is right … at least, I don’t know of any existing VST plugin management utilities for Mac (AU yes, but VST, no) … but if you or a colleague is comfortable with a little basic applescripting then it would be relatively easy to write a launch script fro FCP that moves those plugs out of the plugins folder automatically.
  • Arya Boustani
    September 13, 2013 at 3:20 pm
    Hi Andy,
    You mentioned there is a way to make FCP doesn’t read AU plugins.
    Would you be able to point out the steps?
    I have the same situation but regarding AU plugins: using them in a DAW but not need it for FCP.
    Arya
