Activity › Forums › Adobe After Effects › How to simulate spotlight w/gel
  • How to simulate spotlight w/gel
    Posted by John Baum on September 20, 2007 at 7:09 pm
    Trying to simulate multiple spotlights shining on a wall where each spotlight has a shaped colored gel on it. ie- a red star or yellow moon…I know i can sort of fake it with masks and some other tricks, but I was hoping there is a way to set up something that would behave like a light when you animated it.
    I thought I found the answer in the cc spotlight effect, but I can’t figure out how to use the gel option to get the look I want.It just shows the spotlight cut off in a weird way which doesn’t seem to correlate to the masked solid I am using as a gel layer.
    David Bogie replied 19 years ago 3 Members · 3 Replies
  • Kevin Camp
    September 20, 2007 at 7:30 pm
    pre-comp you mask layer, choosing move all atributes. cc spotlight wants the gel to be a single layer with transarency, so layers with masks or track mattes need to be pre-comp’ed.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Kevin Camp
    September 20, 2007 at 7:31 pm
    i should have mentioned, pre-comp each ‘gel’ individually…
    Kevin Camp
  • David Bogie
    September 21, 2007 at 1:34 pm
    The coolest way to do this is to use a layer as a gobo for a light in a 3D project. That way the light casts accurate shadows and elongates realistically if it is moved.
    bogiesan
