Activity Forums Apple Motion how to simulate 24p?
  • how to simulate 24p?
    Posted by Jason on February 11, 2006 at 11:51 pm
    I am shooting a documentary and I am using a DSR500ws DVCAM camera. It is a native widescreen cam that shoots 29.97 fps. What is the best way to simulate 24p in post?
    I use FCP5, Motion and After Effects 6.5.
    I may be willing to purchase a 3rd party prog/plugin if necessary…I just want it to look as much like film as possible without the high cost of shooting film or renting a 24p camera.
    Jason
    Peter Wiggins replied 20 years, 7 months ago 3 Members · 3 Replies
  • Peter Wiggins
    February 12, 2006 at 12:10 am
  • Lu Nelson
    February 25, 2006 at 6:21 pm
    The best way is to convert your footage to 24p before you start editing; but it depends how much footage you have. It is extremely time intensive.
    You can also do it when you finish your cut. In either case you use Compressor — since you are using FCP5 and Motion2, you must also have Compressor 2.
    Compressor 2 can do very high quality frame rate conversions and de-interlacing, using the same optical flow technology that is built in to Shake. The results are better than any plugins currently available for FCP, better than DVFilm and better than Magic Bullet, but it is slow. Basically you create a preset in Compressor that will take your program and convert 29.97i to 23.976p. Run some tests on material that has cuts and dissolves in it though, to see how they turn out — I’ve only tested it on single shots; but I promise if you do it at the highest quality settings, you will be stunned by the results.
    Look around on the FCP board for other techniques vis a vis Compressor. It’s also a very powerful way to speed-convert clips.
  • Peter Wiggins
    February 25, 2006 at 6:33 pm
    But why 24P, are you going to film?
    If you are staying with video, make it 30/25P as I suggested above
    Peter
    Free Motion Templates
    https://www.peterwiggins.com
