Activity › Forums › Adobe After Effects Expressions › How to setValue to Trapcode particular size over life?
  • How to setValue to Trapcode particular size over life?
    Posted by Clifford Li on February 15, 2017 at 3:43 am
    Hi everyone,
    I am writing a script to drive “Trapcode particular” plugin.
    Other properties like “Particles/sec”, I can simply write – property(“Particles/sec”).setValue() to drive the value.
    But the .setValue() not working on “Over Life” type parameter, such as “Size over Life” or “Opacity over life”.
    So, how can I set the value to these “over life” by script?
    Xavier Gomez replied 9 years, 7 months ago 3 Members · 6 Replies
  • Dan Ebberts
    February 15, 2017 at 2:30 pm
    My guess is that those are a custom data type, so you won’t be able set those with a script.
    Dan
  • Clifford Li
    February 15, 2017 at 5:16 pm
    Hi Dan,
    Coz I found some script at least can set value to pick the “presets” of “size over life”. (It kinda like drop down menu)
    But of course it’s a jsxbin file…
    So I am actually wondering how script can set value to “size over life presets menu”.
    Clifford
  • Dan Ebberts
    February 15, 2017 at 5:38 pm
    Your script could apply a preset (.ffx) that has that parameter specified.
    Dan
  • Clifford Li
    February 16, 2017 at 3:38 am
    Nice idea, Thank you Dan
  • Clifford Li
    February 17, 2017 at 11:08 am
  • Xavier Gomez
    February 18, 2017 at 2:59 pm
    Shot in the dark as i dont have particular:
    Reading your description of the parameter (dropdown), you could try setting the value as an integer (1 for first choice, 2 for 2nd choice, etc):
    myProperty.setValue(2);
    (For dropdown properties, the string is only a display info, what counts internally is the index of the menu item).
    Xavier
