Activity Forums Adobe Premiere Pro How to set video resolution exporting a video?
  • How to set video resolution exporting a video?
    Posted by Maxim Egle on August 19, 2020 at 8:48 pm
    I want the result video in 640x480p format. But there is no such option. Not for .avi neither for .mpeg4. Only 720x480p. The original video which I want to export is in 640x480p format too. Help please.
    Jeya Prakash replied 6 years, 1 month ago 4 Members · 5 Replies
  • Rich Rubasch
    August 19, 2020 at 10:42 pm
    In that case you would just check the box to preserve current frame size, or maybe it’s frame size from source.
    Rich
    Rich Rubasch
    Tilt Media Inc.
    Video Production, Post, Studio Sound Stage
    Founder/President/Editor/Designer/Animator
    http://www.tiltmedia.com
  • Todd Perchert
    August 20, 2020 at 12:25 am
    Back in the day, I don’t recall a 640x480p – it was all interlaced (lower field first). I wonder where that footage originated…
    Anyhow, if your source is 640x480p, you can drag it to the “new item” icon in the lower left of the bin and that will create a sequence that matches the source. Then you should be able to export with Match Source on Export. At what point are you not getting what you need?
    TC
  • Maxim Egle
    August 20, 2020 at 3:21 pm
    Thank you!
  • Maxim Egle
    August 20, 2020 at 3:22 pm
    Thank you.
    I already got throw. I needed just to check a checkbox.
  • Jeya Prakash
    August 21, 2020 at 5:49 am
    THank you
