Activity › Forums › Adobe Premiere Pro › How to set up 16 FPS project in premiere CS6
  • How to set up 16 FPS project in premiere CS6
    Posted by Gordon Stewart on July 19, 2014 at 1:33 pm
    I’m importing image sequences that were made in C4D at 16 fps. There is no setting for 16fps in PPro, even in the custom mode, just 15 then up to 23.976. Is there a way to do this? Thanks.
    Phil Radelat replied 12 years, 2 months ago 3 Members · 4 Replies
  • Ann Bens
    July 19, 2014 at 1:57 pm
    Image sequence as in stills?
    Import and then drag the clip into the new item icon (bottom left Project window) and it will create a matching sequence.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Gordon Stewart
    July 19, 2014 at 2:11 pm
    Since images don’t have any FPS the way a video sequence would, I still need a way to set the project’s output to 16FPS. When you import a sequence of images, they use the project settings for fps.
  • Ann Bens
    July 19, 2014 at 3:53 pm
    There is no way to export to 16 frames.
  • Phil Radelat
    July 19, 2014 at 8:59 pm
    Unless you plan to do any type of image processing in PP, you’re better off using another app. On the PC side, you can used the free app VirtualDub to do this.
