Activity › Forums › Apple Final Cut Pro › How to set time earlier
Posted by Tony de La Dolce on December 24, 2022 at 10:16 pmHello,
First post so hope someone can help. I have 3 videos and trying to work this out (see attached print screen).
Video 3 is my master video and sound track. In order to synch videos, I need to match/synch the sounds highlighted with circles A and B. Problem is:
I can’t set the video 2 before the 0:00:00 mark… anyway to “send” video 2 like 16 seconds or so before this 0:00:00?? or any way to add those 16 seconds to video 3???
Thanks for your help
Tony de La Dolce replied 3 years, 9 months ago 3 Members · 5 Replies -
Gregor Myller
December 26, 2022 at 1:09 pmSince you are using three different clips, you can use the multicam option within FCP.
You select the three clips in the browser part and right click to create a new multicam clip and then select the method of synchronization (audio or timecode) and you get a new clip you can open by double clicking and then you can move any clip around.
Here is a tutorial on YouTube: How to do Multicam Editing in Final Cut Pro | FCPX Tutorial
And here is the search I used to find that: https://www.youtube.com/results?search_query=final+cut+pro+multicam+editing
If you do not want to use multicam editing, you can insert a gap clip (CMD+W) at the position of the red timeline marker. That moves the clip 3 to the right and you can move clips 2 and 1 to the left.
Or you trim clips 2 and 1 at the beginning, then they can be moved around as well. But multicam editing is the way to go with multiple cameras.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Ben Balser
December 26, 2022 at 5:41 pmYou can drag any of those videos to the left, it’ll let you.
If you drag the clip in the main storyline, the connected ones will move with it, unless you also hold the ~ key, which overrides magnetic timeline functions.
Or make make a multicam clip out of them, if there’s some specific advantage to that in reaching your goal.
Tony de La Dolce
December 28, 2022 at 4:33 pmThanks for the info and links… I didn’t know this function (Multicam) and learned it with various “how to” like the one you pointed out.
I spent hours fixing a very stupid thing and I’ll add the info here in case it can be useful for the next dummy that comes around like me.
When having one timeline for all the videos, it is super easy to open them all by double clicking on this “windows” logo and all vids open up which allows further modifications on each movie. However, I really struggled to get back to the main timeline video in order to switch the cams… I literally spent hours on this!
In order to get back to that “main” timeline, simply go into the menu in the timeline frame and close the “Multicam name” and voilà.
I’m really new to this and I did suffer (a lot) to put together this 20mn video but it is done and I’m quite happy with the result for a first attempt 😁
Thanks again for your help and comments!
Ben Balser
December 29, 2022 at 1:41 pmThese are very basic operations that should only take a few minutes. I’d strongly recommend doing a proper FCPX training to save you hours of headaches and frustration. Ripple Training and macProVideo have the best.
Tony de La Dolce
December 30, 2022 at 11:01 amObviously, I’m sure there is a lot of things I could learn thanks to such training.
That said, I come from the photography world and really got into “movie” just because some friend asked me to come and shoot a movie in this cathedral for their live concert… some 24h before it did happen 😂
I’m happy with the result and there are tons of things to do better for next time… but for the moment, that’s only a hobby really. If that goes more serious, I’ll get a training and maybe buy that software that I’m still using as a “trial” version… for 80 more days 😂
Anyway, thanks for the feedback.
