Activity Forums Blackmagic Design how to set the used reference
  • how to set the used reference
    Posted by Hung Han on December 20, 2010 at 6:44 pm
    Hi
    I wish someone could help us to set the input reference used by the application “DecklinkKey.exe” (SDK 7.9)…
    We are using a color bar as input signal and reference input, when we select the “Key Control” to “Off” the output’s reference is
    the same to the signal that is on “Ref-in” but when we select the “Key Control” to “Internal” the output’s reference is
    different, it’s seen that it is locked by another reference… Because the horizontal position reference is
    different from the input reference signal and it’s seen the signal is locked at a “random” position because it is never at the same
    position
    We are using the 7.9 drivers, Windows XP and we have a Decklink Studio 2. This is happening at SDI and Analog signal
    Could you help us to find where could we set at the code to use the same reference input (preferencialy
    the one used by “Blackmagic Control Panel”) or give us any suggestion?
    Regards,
    Hung
    Hung Han replied 15 years, 7 months ago 1 Member · 4 Replies
  • Hung Han
    December 21, 2010 at 10:10 am
    I’m sorry, the horizontal reference position is OK. The VERTICAL reference position is changing
    Regards
    Hung
  • Hung Han
    December 28, 2010 at 4:07 pm
    Hi
    Could anyone help us?
    Regards,
    Hung
  • Hung Han
    January 3, 2011 at 4:09 pm
    Hi
    Is it possible to select which reference to use using a decklink?
    Regards,
    Hung
  • Hung Han
    January 31, 2011 at 4:26 pm
    Hi
    No one knows?
    Regards,
    Hung
