Activity Forums VEGAS Pro How to set Previous skip button
  • How to set Previous skip button
    Posted by Fraser on December 8, 2005 at 9:27 pm
    I have 5 videos I can skip through all my different videos using the Next Remote button but when I want to got back using the previous button it keeps me in that same video. It dose not go back to the previous video. Is thier a way to make it go back to all the videos without using go to the Main Menu and start all over again?
    Fraser
    Edward Troxel replied 20 years, 9 months ago 2 Members · 1 Reply
  • Edward Troxel
    December 8, 2005 at 10:06 pm
    So you have 5 separate files and they are End-Action’d together? And each file is a separate chapter?
    “Next” will go forward through those files. Unfortunately, “Previous” will NOT go backwards through the files. If you had multiple chapter points inside any of the files, it would go backwards through those chapter points but then stop at the beginning of that file.
    You might try making a music compilation using those files and see if that helps. Don’t let the name fool you – it will accept and play video files!
    Edward Troxel
    JETDV Scripts
