Activity › Forums › Adobe After Effects Expressions › How to set global variables and/or Functions in composition
  • How to set global variables and/or Functions in composition
    Posted by Evan Jenkins on March 29, 2020 at 6:40 pm
    I have a massive piece of code that sets variables by referencing sliders in a control layer.
    I have 30 layers where I apply this same piece of code. If I need to adjust the code, I have to delete 29 layers, and then re-do them all haha. It’s crazy.
    Is there some way to make my variables global, so those variables apply to all layers? Can I get a function to apply to all layers?
    myID = effect("myID")("Slider");
    firstPhotoInPoint = thisComp.layer("Control Sliders").effect("firstPhotoInPoint")("Slider");
    checkSections = thisComp.layer("^sections").text.sourceText;
    sectionOneStart = thisComp.layer("Control Sliders").effect("sectionOneStart")("Slider");
    sectionOnePhtNum = thisComp.layer("Control Sliders").effect("sectionOnePhtNum")("Slider");
    sectionOneDur = thisComp.layer("Control Sliders").effect("sectionOneDur")("Slider");
    sectionOnePhtTime = sectionOneDur / sectionOnePhtNum;
    sectionTwoStart = thisComp.layer("Control Sliders").effect("sectionTwoStart")("Slider");
    sectionTwoPhtNum = thisComp.layer("Control Sliders").effect("sectionTwoPhtNum")("Slider");
    myIDSectionTwo = myID - sectionOnePhtNum;
    sectionTwoDur = thisComp.layer("Control Sliders").effect("sectionTwoDur")("Slider");
    sectionTwoPhtTime = sectionTwoDur / sectionTwoPhtNum;
    sectionThreeStart = thisComp.layer("Control Sliders").effect("sectionThreeStart")("Slider");
    sectionThreePhtNum = thisComp.layer("Control Sliders").effect("sectionThreePhtNum")("Slider");
    myIDSectionThree = myID - sectionOnePhtNum - sectionTwoPhtNum;
    sectionThreeDur = thisComp.layer("Control Sliders").effect("sectionThreeDur")("Slider");
    sectionThreePhtTime = sectionThreeDur / sectionThreePhtNum;
    sectionFourStart = thisComp.layer("Control Sliders").effect("sectionFourStart")("Slider");
    sectionFourPhtNum = thisComp.layer("Control Sliders").effect("sectionFourPhtNum")("Slider");
    myIDSectionFour = myID - sectionOnePhtNum - sectionTwoPhtNum - sectionThreePhtNum;
    sectionFourDur = thisComp.layer("Control Sliders").effect("sectionFourDur")("Slider");
    sectionFourPhtTime = sectionFourDur / sectionFourPhtNum;
    sectionFiveStart = thisComp.layer("Control Sliders").effect("sectionFiveStart")("Slider");
    sectionFivePhtNum = thisComp.layer("Control Sliders").effect("sectionFivePhtNum")("Slider");
    myIDSectionFive = myID - sectionOnePhtNum - sectionTwoPhtNum - sectionThreePhtNum - sectionFourPhtNum;
    sectionFiveDur = thisComp.layer("Control Sliders").effect("sectionFiveDur")("Slider");
    sectionFivePhtTime = sectionFiveDur / sectionFivePhtNum;
    if (checkSections == "sections" && myID <= sectionOnePhtNum) {
    timeElapsed = sectionOnePhtTime * (effect("myID")("Slider") - 1);
    timeStart = firstPhotoInPoint + timeElapsed;
    } else if (checkSections == "sections" && myID <= (sectionOnePhtNum + sectionTwoPhtNum)) {
    timeElapsed = firstPhotoInPoint + sectionOneDur + (sectionTwoPhtTime * (myIDSectionTwo - 1));
    timeStart = timeElapsed;
    } else if (checkSections == "sections" && myID <= (sectionOnePhtNum + sectionTwoPhtNum + sectionThreePhtNum)) {
    timeElapsed = sectionThreeStart + (sectionThreePhtTime * (myIDSectionThree - 1));
    } else if (checkSections == "sections" && myID <= (sectionOnePhtNum + sectionTwoPhtNum + sectionThreePhtNum + sectionFourPhtNum)) {
    timeElapsed = sectionFourStart + (sectionFourPhtTime * (myIDSectionFour - 1));
    } else if (checkSections == "sections" && myID <= (sectionOnePhtNum + sectionTwoPhtNum + sectionThreePhtNum + sectionFourPhtNum + sectionFivePhtNum)) {
    timeElapsed = sectionFiveStart + (sectionFivePhtTime * (myIDSectionFive - 1));
    } else {
    photoTime = thisComp.layer("Control Sliders").effect("photoTime")("Slider");
    timeElapsed = photoTime * (effect("myID")("Slider") - 1);
    valueAtTime(time - timeStart);
    Evan Jenkins
    Aspen Films Inc.
    aspenfilms.ca
    Evan Jenkins replied 6 years, 6 months ago 2 Members · 5 Replies
  • Andrei Popa
    March 29, 2020 at 7:10 pm
    Create a text layer. Put all this code in the text value. And on all your layers put this as expression:
    eval(thisComp.layer("Text Layer").text.sourceText)
    I think you’ll need to change the name of the layer. You can make it invisible so it does not mess with your design.
    Andrei
    My Envato portfolio.
  • Evan Jenkins
    March 29, 2020 at 7:35 pm
    Thanks I copied and pasted my code into the text layer and then added the eval, but I got an error, it says Object of type TextProperty found where a Number, Array, or Property is needed
    Evan Jenkins
    Aspen Films Inc.
    aspenfilms.ca
  • Andrei Popa
    March 29, 2020 at 7:44 pm
    Maybe add .value at the end. Some of this small things changed with the expression engine.
    eval(thisComp.layer("Text Layer").text.sourceText.value)
    Andrei
  • Evan Jenkins
    March 29, 2020 at 8:01 pm
    I think I’m making progress, now it says “Syntax Error”
    The .value seemed to work.
    Also I saw an old post on the forum where you can add “””Code Here””” (triple quotes) in the text layer to make sure you’re converting everything into a single character string.
    I’m still working at it trying to resolve the error.
    Evan Jenkins
    Aspen Films Inc.
    aspenfilms.ca
  • Evan Jenkins
    March 29, 2020 at 8:19 pm
    I gave up out of trying to get the code out of a text layer, there was something wrong with what I was doing but I couldn’t figure it out.
    I actually had more success with getting the code out of the comments of a layer marker, which also has the advantage of letting me scroll through a little easier to access the code.
    I got the idea from this video:
    https://www.youtube.com/watch?v=MX4dUF0J5x0
    eval(thisComp.layer("Set Global Variables").marker.key(1).comment);
    Evan Jenkins
    Aspen Films Inc.
    aspenfilms.ca
