Activity › Forums › VEGAS Pro › How to set correct proj properties for this?
  • How to set correct proj properties for this?
    Posted by Gilles Gagnon on January 27, 2013 at 8:57 pm
    I’m making a slideshow with images taken from a digital camera.
    The images are 2048×1536.
    I’ve set my proj properties to match this media using the utility in “project properties”
    Is this the correct way of doing this?
    am I then left to have black vertical bands on either side of the images when I render the video?
    I’m rendering using MC mp4. Which template should I use for something like this?
    Cheers,
    G
    Gilles
    Mark Barton replied 13 years, 8 months ago 3 Members · 5 Replies
  • Stephen Mann
    January 28, 2013 at 1:47 am
    See if this helps:
    https://forums.creativecow.net/readpost/24/927034
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Gilles Gagnon
    January 28, 2013 at 1:36 pm
    Hey Steve,
    Thanks for this post. I think this is just what I’m looking for. I missed it in my search.
    I’ll give it a try.
    Gilles
  • Mark Barton
    January 30, 2013 at 6:02 am
    I usually set it to what my main delivery format will be. When I put together a slide show/ video presentation for the Boy Scout Troop, I render to 720p as my projector connected to my laptop does not support 1080p. If I am doing something for my big screen TV at home, then I render to a 1080p.
    If I am dealing with a few hundred photos, many times I will leave them in the original jpg format I got them in. I use the montage tool in Production Assistant 2 to create the slide show.
  • Gilles Gagnon
    January 30, 2013 at 12:25 pm
    Thanks Mark,
    I was working on it last night. I ended up using a 4:3 project size. It matched my photos the closest in terms of size.
    It’s a personal project and therefore was willing to concede somewhat.
    What’s strange, and if someone could explain, is that although I “matched output aspect ratio” on my pics, and although it all looked fine in the preview window, after the render (4:3) main concept mp4, I now have a very thin top and bottom thin black line in the quicktime viewer output.
    Gilles
  • Mark Barton
    January 30, 2013 at 6:31 pm
    I have seen that before and the way I took care of it was to make sure the project properties matched the render as template.
