Activity Forums Adobe After Effects How to set adjustment layer mask?
  • How to set adjustment layer mask?
    Posted by Aaron Hayman on May 1, 2011 at 12:29 am
    Ok… what I have is a solid shape that moves over some video footage. I want to “cut a hole” in that solid shape that shows the video underneath through that hole. This hole has to be able to move independently of the the solid shape that it’s cutting out.
    I was shown a quick demo of how to achieve this using an adjustment layer that then has a mask on it and then the mask can be animated. The trouble is that I’m unable to re-create this. What settings do I need to use? Should the adjustment layer be above or below the shape layer that it’s cutting out? I think that the shape layer actually needs to be turned off so that only the alpha is activated (not the actual solid shape), but I’m not sure on this one either. What are the settings that the shape layer should have and what are the settings for the mask on that layer?
    Thank you very much in advance.
    David Johnson replied 15 years, 4 months ago 2 Members · 1 Reply
