Activity Forums VEGAS Pro How to set Ac3 audio?
  • How to set Ac3 audio?
    Posted by Jon Smith on August 21, 2009 at 11:09 pm
    how do you set your audio to ac3? I have been looking under rendering/audio tab and can’t find it.
    Theo Van laar replied 17 years ago 3 Members · 7 Replies
  • 7 Replies
  • Theo Van laar
    August 21, 2009 at 11:22 pm
    FILE-RENDER AS
    see attachment:
    222_ac3.jpg.zip
    Theo
  • Jon Smith
    August 21, 2009 at 11:33 pm
    Thanks Theo!
    So you basically render them completely separate and import both files to the DVD?
  • Theo Van laar
    August 21, 2009 at 11:39 pm
    Hi Jon,
    Most of us render video and audio as separate files, which get exactly the same name (apart from the extention). Both files are placed in the same folder!!!
    In DVDA, you only import the videofile. The audio file will follow automaticly (if the are in the same folder and have the same name).
    Theo
  • Jon Smith
    August 22, 2009 at 12:01 am
    Theo, thank you for being so helpful. Right now I rendered to: DVD Architect 24p NTSC Widescreen video stream template under the MainConcept MPEG-2 type for a regular DVD burn. What do you suggest I change the video part to in order to burn in HD to Blue Ray?
  • Theo Van laar
    August 22, 2009 at 12:09 am
    It depends. If your footage is HD and you have a full HD TV + BD player, I would just make BD. But if you are making the disk for someone else and you are not sure whether he/she/they is/are HD-proof, I would just make a normal DVD.
    Theo
  • Wayne Anderson
    August 28, 2009 at 5:36 pm
    What is the purpose of rendering in two files? I render video in MPEG-2, and the template “DVD-A stream”, and if you go to “custom” and “audio” you can check “include audio stream”. Seems to work okay for making a DVD. What am I missing?
  • Theo Van laar
    August 28, 2009 at 8:31 pm
    This is to prevent that DVDA will re-encode the audio to AC3, which leads to loss of quality.
    Theo
