Activity › Forums › Adobe Premiere Pro › how to set a specific time code
Posted by Ronaldo German on June 12, 2013 at 5:25 pmHow can I set a specific time code of a chosen frame inside Premiere Pro 6?
ThanksMuthu Ayyeppen replied 12 years, 7 months ago 5 Members · 7 Replies -
Kris Merkel
June 12, 2013 at 6:35 pmA little more descriptive of a question might help get you the answers you are looking for. What are you trying to do?
“Think of everything in terms of building capacity.”
Kris Merkel
twitter: @kris_merkel
Product Manager, Flanders Scientific Inc.
http://www.shopfsi.com
Co-Founder, Atlanta Cutters Post Production User Group
http://www.atlantacutters.com2.2Ghz MBP core i7
16Gb RAM
CS6/FCP7
AJA T-Tap
AJA IO XT
FSI LM-2461W/CM-170W -
Ann Bens
June 12, 2013 at 6:52 pmNot quite sure what you are asking, but 2 options:
go to the flyout menu of the timeline and check Start Time.
You can set any time for the first frame.
Or use the Timecode effect.———————————————–
Adobe Certified Expert Premiere Pro CS6
Adobe Community Professional -
Ronaldo German
June 12, 2013 at 8:41 pmA big company who I´m dealing a film with is asking:
“Start of feature time code location will be one hour (01:00:00:00). Start of color bars time code will be back-timed from the one hour (01:00:00:00) start of feature location.”So I understand (correctly or not) that I must set a new time code in my timeline before exporting the edited file (to be delivered), that should be 01:00:00:00 at the first frame of my feature film.
What should I do? -
Kevin Monahan
June 12, 2013 at 9:10 pmHi Ronaldo,
In the Timeline panel menu, choose Start Time, enter a starting timecode, and click OK. (The starting time must be a positive number.)Hope that helps,
KevinKevin Monahan
Social Support Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
Ronaldo German
June 12, 2013 at 9:49 pmWell, it`s weird.
The exported file didn`t keep my change in start time, despite the timeline (and the its respective project) kept it.
The exported file timeline started at 00:00:00:00 as before my change.
What`s going on? -
Muthu Ayyeppen
February 13, 2014 at 11:38 amHello,
with Premiere Pro CC 7.2.1, is there a possibility in the export settings or profiles (PPro or AME) to force set timecode of exported medias. I’m aware it takes the timecode of sequence and it works brilliantly well. I can see in the export media dialog there is an option of “Set start timecode to 0”. Is there a way to set user defined timecodes, say 05:00 or 10:00 ? the reason I’m asking this we transcode or export around 50-100 medias everyday and we need user defined timecode setting option.
Muthu
