Activity › Forums › VEGAS Pro › How to set 1 second fade in/out on all media automatically when added to the timeline
  • How to set 1 second fade in/out on all media automatically when added to the timeline
    Posted by Derick Boe on April 19, 2013 at 7:20 pm
    Is there a way to set this in Vegas Pro 12? I’m manually editing each media (mediaFX, sound, video) to fade in and out within 30 frames (project set to 30 fps=1 second).
    I would like to have it so that when I drag something from Media to my timeline, it automatically has a 1 second fade in/out event.
    Please advise, otherwise this is going to take hours of extra time. 🙁
    Thayalan Paramasawam replied 13 years, 5 months ago 6 Members · 12 Replies
  • 12 Replies
  • John Rofrano
    April 19, 2013 at 8:25 pm
    [Derick Boe] “I would like to have it so that when I drag something from Media to my timeline, it automatically has a 1 second fade in/out event.”
    There is no way to set an automatic fade.
    [Derick Boe] “Please advise, otherwise this is going to take hours of extra time. :(“
    My advice would be to get the VASST Event Tool plug-in. With one click it will add fades to all of your selected events and a whole lot more. What would have taken hours will literally take seconds.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Derick Boe
    April 19, 2013 at 9:25 pm
    That worked perfectly thank you. Another question; I have a bunch (100+) images that I want to span for 10 seconds each on the video stream. Is there a way to make them all the same length on the same stream? Can I copy the properties of 1 image and apply it to all the others?
    Sorry about the questions, I’m not a pro. I saved up for 4 years to be able to afford Vegas, and this is mostly for home projects.
  • Graham Bernard
    April 20, 2013 at 4:31 am
    I see 3 Options for you:-
    OPTION I:
    If you now have the VASST Event Tool,
    1] Selection Tab : Select All Events > APPLY
    2] Adjustment Tab : Adjust Selected Event Length to 00:00:10.00 > APPLY
    3] Transition Tab : Change the “Length” to ZERO > APPLY
    All Stills will now be at 10 seconds.
    OPTION II
    If you DON’T have the VASST Event Tool and DON’T yet have your Stills on the Timeline,
    1] Main Toolbar > Options > Preference > Editing Tab
    2] And adjust “New Still image length ” to 10:-
    Drag Stills to Timeline, job done!
    OPTION III
    If you ALREADY have Stills on timeline then create a Group of ALL the Stills and use the Ctrl+Drag method to stretch stills to the required length.
    Cheers
    Grazie
  • Thayalan Paramasawam
    April 20, 2013 at 9:30 am
    Thanks Sir (MrJohn Rofrano and Mr.Graham Bernard)…..its help to
  • John Rofrano
    April 20, 2013 at 11:25 am
    [Derick Boe] ” I have a bunch (100+) images that I want to span for 10 seconds each on the video stream. Is there a way to make them all the same length on the same stream? Can I copy the properties of 1 image and apply it to all the others?”
    Are you trying to make a photo montage? You might want to get VASST Still Motion. It will let you lay out your images of any length with fades, pan/scan motion, match aspect, etc.
    Here is a tutorial of Ultimate S Lite which has even more capabilities but the basic photo montage is very similar:
    Ultimate S Lite Photo Montage
    I don’t mean to sound like I’m always selling you something but our productivity tools can automate a lot of tedious tasks to make your editing experience more enjoyable and Graham has already told you how to do it manually.
    ~jr
  • Graham Bernard
    April 20, 2013 at 11:41 am
    [John Rofrano] “Graham has already told you how to do it manually”
    My OPTION I was my feeble attempt to invite our chum to do it through the VASST Event Tool which may now have.
    Cheers
    Grazie
  • John Rofrano
    April 20, 2013 at 12:14 pm
    [Graham Bernard] “My OPTION I was my feeble attempt to invite our chum to do it through the VASST Event Tool which may now have.”
    Oh yea true, that wasn’t totally manual. I was just trying to look at the bigger picture of what he was actually trying to accomplish rather than answering all of the little questions that might have been answered had he asked, “What’s the fastest way to make a photo montage in Vegas?”. 😉
    ~jr
  • Graham Bernard
    April 20, 2013 at 12:54 pm
    Great tutorial John! Really takes pressure off, and guides a person through the feature-set.
    Grazie
  • Derick Boe
    April 20, 2013 at 1:58 pm
    Those are all excellent suggestions thank you. Exactly what I was looking for.
  • Edward Troxel
    April 20, 2013 at 3:36 pm
    If you’re doing a photo montage, you might want to look at Montage Magic as well.
    Edward Troxel
