How to select multiple objects within other objects
Hi guys
I have a converted Solidworks object (which has been made by someone else), and inside this object are smaller objects (circuit board). Think a Russian Doll. Id like to make a selection and move all these objects at the same time but i only seem to be able to select the outer most layer.
Using the layer panel is useless as there a many unanmed layers which do not apply to what i need to do.
Is there a selection tool to help with this?
Thanks a lot
