Activity Forums VEGAS Pro how to select marker when it’s in same place as region
  • how to select marker when it’s in same place as region
    Posted by Roman Revell on September 23, 2010 at 12:50 am
    So, I have a region and a marker sitting in the exact same place as the first (front) region marker. I can not figure out how to select the “marker” so that I can delete it. If I click on it, it will only select the region flag underneath it.
    Any ideas, keyboard shortcuts?
    Sony Vegas Movie Studio HD Platinum 10 on Windows 7
    thanks,
    Roman
    Luis Vedolin replied 15 years, 11 months ago 6 Members · 8 Replies
  • 8 Replies
  • Stephen Mann
    September 23, 2010 at 1:47 am
    That’s interesting. I haven’t found a need for regions so I never noticed that issue. In my test, I selected the region, move the region start, delete the marker, then snap the region marker back to the start of the region. (That’s why I selected the region first).
    So, tell me about regions and why would I want to use them?
    Steve Mann
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Danny Hays
    September 23, 2010 at 2:01 am
    You should be able to open the markers window and delete it from there.
  • Jeff Schroeder
    September 23, 2010 at 2:17 am
    What markers window?
    http://www.narrowroadmedia.com
  • Mike Kujbida
    September 23, 2010 at 2:22 am
    View – Edit Details.
    Select “Markers” in the “Show” dropdown box.
    To delete a marker, click the appropriate number in the very first column, right-click it and select Delete.
  • Stephen Mann
    September 23, 2010 at 2:38 am
    You beat me to it, Jeff. There’s a Markers Window ??
    Thanks for the tip, Mike.
    BTW, someone educate me. Why or how would I want to use Regions?
    Steve Mann
    http://www.mmdv.com
  • Mike Kujbida
    September 23, 2010 at 2:52 am
    Steve, I’m sure there are other uses as well but I use regions when I’m making an audio CD.
  • Roman Revell
    September 23, 2010 at 3:47 am
    There is no “edit-details” in my view menu. I have no idea what you are talking about there, but the suggestion gave me the idea of what to search for in help. So, I did figure it out.
    Right above the scroll up button, there is a little flag. That’s the marker tool. Clicking on that, then clicking on a region or marker flag will cause the flag to highlight and blink. Pressing the left or right arrow keys will move to the next region/marker flag over. Oddly enough, I still can’t right click to select, nor use the context menu key to get the options for the flag I want, but I can hit the delete key and delete it.
    As to why to use regions… I don’t know if there is some clever better reason, but for me it frames a region of the video that has particular meaning. I could just use two markers, but regions work a little better and I can distinguish between meaningful regions and simply meaningful points.
    Now to figure out how to NOT have regions before a cut out portion of video move when doing the post-edit ripple. Maybe I should just stop using regions.
    Thanks for chiming in guys.
    thanks,
    Roman
  • Luis Vedolin
    September 23, 2010 at 11:33 pm
    I use regions (not often, I must confess) for batch rendering.
    Sometimes I tape dance contests and need to create a clip in flash format for each presentation, for further upload to the website.
    So I put all the clips on a timeline, run a script to create a region for each clip on the timeline and then run a batch render to create the flv files.
