how to see the Audio Mixer ‘recorded’ changes
Ok so I used the Audio Mixer to adjust the audio of a track using the ‘record’ option. Id there any visualization (keyframes or the like) that you can turn on to see where the audio changes? Or do you just have to scrub through and watch the handle move? I want to change some of the peaks to higher or lower, but can`t see where I changed the volume.
