How to see a live update of non-pixulated text and mimic this footage?
I’m trying to mimic this look:
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
So far I have created some text and created a solid white layer – made both 3D and added an ambient light. I plan on adding a point light too so I can blow out the text a bit up close. I suspect there is also some kind of reflective setting applied to the text but on a low setting, giving it a matte semi reflective type look – very subtle though.
When I’m playing at the moment, the text actually looks really pixulated. I’ve checked fast preview and tried all the settings and indeed as I understand from my tutorials, text and shape layers in AE are continually rasterised, so I cannot understand why I am not seeing a sharp image of the text. Draft 3D is not on by the way.
Also, i’ve applied a 15mm camera lens and cranked up the aperture which is working fairly nicely.
Any help appreciated!
Olly Lawer
