Activity Forums VEGAS Pro How To Search For Off-line Media On Timeline?
  • How To Search For Off-line Media On Timeline?
    Posted by Gene Lati on February 9, 2010 at 6:06 am
    With all that I have going on on the timeline I can’t seem to locate a 1 second audio file that’s off line (I probably accidentally deleted the file). Is there a a way to search for the file name (it would be empty on the time line I suppose) on the time line?
    Gene Lati replied 16 years, 7 months ago 4 Members · 4 Replies
  • Joe Mantaratz
    February 9, 2010 at 6:39 am
    If you right click on the media in the time line it will tell you where the file is supposed to be and what the name is. Do a system search for the file name in Windows.
  • Mark Greenwood
    February 9, 2010 at 6:54 am
    I wrote a little script which will show you ALL offline media
    https://mgreenwood.com.au/upload/FindOffline.dll
    Just stick it in your script folder (typically c:\program files\sony\sony vegas 9.0\Script menu)
    Run it on your project – that will tell you on which track and which event is the culprit….
  • Omer Aydin
    February 9, 2010 at 12:57 pm
    In case you are asking about locating an off-line item on a very crowded timeline;
    Go to Project Media window and look for a greyed out item. Sorting items in size will help you find it easily because offline items are 0 in size. Right-click on offline item and choose ‘Select Timeline Events’
    The offline item on timeline will be selected.
    If you still can’t locate the selected items due to a very crowded long timeline, create a new audio track below the existing one(s), locate the item using the method above, then use key 2 on numeric pad to move the selected item down onto the new track.
  • Gene Lati
    February 11, 2010 at 4:22 am
    Mark, it worked perfectly. Use Mark’s script.
