Activity › Forums › Apple Final Cut Pro Legacy › How to scroll/pan across a picture?
Posted by Edward Calabig on February 7, 2010 at 1:34 amI’m making a documentary and was wondering how you scroll/pan across/voom in/out of a still picture (kind of like those archaic history educational videos).
Peter Wiggins replied 16 years, 7 months ago 3 Members · 4 Replies -
John Fishback
February 7, 2010 at 2:00 amYou start with an image that’s bigger than your frame size. That allows space to zoom in, pan, etc. In FCP you can set keyframes in the motion tab. However, FCP is challenging to get good results. It’s better to do this in Motion. If you search the Cow you’ll find posts and tutorials. Also, Digital Heaven has a plugin called DH_Box which is a handy tool that works inside FCP. Many folks do this work in AfterFX which affords excellent control.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Peter Wiggins
February 7, 2010 at 6:56 pmEdward,
I cannot stress how easy this free plugin makes the ‘Ken Burns’ style of moves on still images
https://www.noiseindustries.com/fxfactory/panandzoom/Another company makes a similar plugin and charges $199!!!!
Here is a little demo video to show you how it works too.
https://www.youtube.com/watch?v=Mh_kBe0Dkcw
Peter
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
John Fishback
February 7, 2010 at 8:02 pmI can’t believe I forgot about Pan & Zoom 2. I’ve used it and it’s excellent.
John
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Peter Wiggins
February 7, 2010 at 8:55 pmyeup, the quadratic movement in/out is the best yet slightly hidden feature.
Peter
