Activity › Forums › Apple Final Cut Pro Legacy › How to scale/resize multiple objects in a sequence?
  • How to scale/resize multiple objects in a sequence?
    Posted by Matty Smith on March 22, 2013 at 4:19 am
    Hopefully this makes sense: I’ve got several PNG images layered in a sequence, and I’m trying to see if there’s any way to resize them all at once (ideally, using the wireframe) together. I’d like to copy all of the images into a different sequence to create a closer “angle”. I can’t just copy and paste attributes or just use the scale percentage in the motion tab because they’re all various sizes and have been already resized to fit together (basically, the original PNGs aren’t fitted together).
    Is there any way to do this, akin to grouping layers in PhotoShop so I can just click and drag the size of all of them together?
    Dennis Radeke replied 13 years, 6 months ago 3 Members · 5 Replies
  • Shane Ross
    March 22, 2013 at 4:35 pm
    OR…size one up by adjusting scale and position. Copy the clip, then paste attributes on all the other clips.
    Shane
    Little Frog Post
  • Matty Smith
    March 22, 2013 at 5:39 pm
    So the answer’s “no” when it comes to doing it how I described? The stills are all timed out in the one sequence already, so I’m trying to find a way where I can copy and paste them all from another sequence so the timing is all the same.
    Or is there an easy way to replace all the stills with the resized versions quickly? It’s the same two stills switching back and forth a LOT, so it would need to be a quick easy way to do a mass replacement.
    And as I said, I can’t copy and paste the attributes because the stills are different sizes and the relative scale isn’t the same.
  • Shane Ross
    March 22, 2013 at 6:06 pm
    OH, so you used the stills in an SD sequence, for example, and now you want to copy and paste them into an HD sequence…and just scale them all up but keep the same moves…just one easy step?
    Nope…sorry. Gotta manually adjust each and every one. I’ve been down that road many times. offline/online editing with loads of stills. Which is why I prefer they do the moves in After Effects or Motion, render them out in full HD, and use those in the SD sequence. Scaling QT up is a one click process.
    Shane
    Little Frog Post
  • Matty Smith
    March 22, 2013 at 6:46 pm
    Okay cool, thanks guys. I knew it wasn’t the best approach to things but I’m doing some things on the fly and wanted to see if there was a way.
    Appreciate the help!
  • Dennis Radeke
    March 23, 2013 at 1:37 pm
    I would only add to Dave’s comment that you can save this as a batch process command. So after creating the actions needed to resize, you can apply to all clips in a folder.
