Activity › Forums › Adobe After Effects › How to scale layer behind mask?
Posted by Elizabeth Winter on June 5, 2009 at 7:21 pmHi, I know about the pan behind tool but is there a SCALE behind tool that allows for scaling a layer without modifying a mask?
Thank you.John Hammond replied 12 years, 1 month ago 4 Members · 5 Replies -
Adolfo Rozenfeld
June 5, 2009 at 7:57 pmThere are two ways.
The first may sound a bit complicated but will help in any case in which you may want to alter the rendering order. In this case, process the scale transformation after the mask, instead of the other way around (if you adjust scale and the mask also is scaled, that is prof that masks are usually calculated before transformations like scale in the processing chain).
These are the instructions I wrote a couple of days ago:https://forums.creativecow.net/readpost/2/958166
The other way is with a Track Matte:
Create a solid with the same dimensions as your layer, and place it so it’s immediately above in the timeline. Cut the mask and paste in the solid. Set the original layer’s track matte mode to Alpha (next to the blend modes in the timeline).Adolfo Rozenfeld · Adobe
Matt Carl
June 5, 2009 at 8:38 pmAnd the third way to do it would be to make a pre comp. Put the object you want to scale in a pre comp and do whatever scale change/ panning/ whatever you want in it. Then back in your master comp put the mask on this pre comp. This way the size of of you object won’t affect your mask since your pre comp is staying the same size.
John Hammond
July 24, 2014 at 10:03 amI just came across this problem.
In my case it was solved by just cutting the masks out of the layer, scaling the layer, and pasting them back in.
I was seriously overthinking it
