Activity Forums Adobe After Effects How to scale a circle but keep stroke width constant?
  • How to scale a circle but keep stroke width constant?
    Posted by Ste Kerouac on July 20, 2006 at 12:06 am
    I need to create a number of very simple circle outlines which scale up, but retain a constant stroke width. Ideally I’d like to be able to control the stroke width as an independent parameter so I can alter it slightly as well. I’ve tried the stroke filter but that scales up and down with the scale of the mask. Any ideas?
    Mike Clasby replied 20 years, 2 months ago 3 Members · 3 Replies
  • Roland R. kahlenberg
    July 20, 2006 at 3:18 am
    You should be using RadioWaves.
    Cheers
    Roland Kahlenberg
    https://www.broadcastGEMs.com
    customizable animated backdrops with Adobe After Effects project files
  • Ste Kerouac
    July 20, 2006 at 9:59 am
    Okay thanks… that probably is going to be the best way to do it. Somebody else recommended boris cartooner which might be helpful for a different user.
  • Mike Clasby
    July 20, 2006 at 7:02 pm
    Did you try keyframing the Mask Shape, that works on my machine, leaving Stroke or Audiowaveform the same size as the Mask Shape enlarges (Audiowaveform: Path – Mask 1, and the same layer selected as the audio layer, display option: Analog Lines, = no real audio waveform bouncing, only a cool stroke)? You could also decrese the stroke/Audiowaveform) as the circle increases, or wiggle it (ooo, I like that, hadn’t done it before), your choice.
    To get uniform Mask shape change, double click the mask, and Ctrl + Shift drag a corner (like doing a PhotoShop Transform).
    Shift keeps it circular, Ctrl makes it expand from the center.
    Audiowaveform: Path – Mask 1 (I’m assuming the Mask is on a Solid Layer, with “none” instead of “Add” for the Mask type, and the same layer selected as the audio layer (don’t tie it to an real audio layer), display option: Analog Lines, = no real audio waveform bouncing, only a cool stroke)?
    You might be saying “What’s with this Audiowaveform?”, I dunno, I like it most times better than Stroke, what with the inner and outter color, but then I was always a sucker for Neon Lights.
