Activity › Forums › Adobe Premiere Pro › how to save to dvd after exporting as mpeg-2 for dvd
Vincent Rosati replied 17 years, 3 months ago 2 Members · 23 Replies
Vincent Rosati
May 27, 2009 at 9:30 pmI don’t think you can use AME to create a disc, but Premiere has a disc creation function. I never use that though, I’ve tried it, but I’ve had problems.
When are you getting the crash in Encore? Are you getting an error code?
Regarding the transform settings for the pics, I cant find my notes, and I’m in a crunch right now. I can’t say when I’ll have them. 🙁
Vince
Lillian Fidler
May 27, 2009 at 9:49 pmThanks Vince, no problem, whenever you can is fine.
The error I’m getting in ae is when I start to burn the disk. It starts and goes through the first process of preparing, then it just says cancelling and stops and ejects the disk, each time I have to restart the program for it to work again. When I try to save to a folder it starts writing and then comes back with a ‘memory allocation error.
boo!
Lillian
Lillian Fidler
Jillian Productions
St. John’s, Newfoundland
Canada -
Vincent Rosati
May 27, 2009 at 10:03 pmCheck to make sure the length of your audio and video tracks are identical. Adjust if necessary.
Than, if you’ve created chapter points in Premiere, you may need to adjust them in Encore.Stick with the option to create a DVD folder (TS_VIDEO folder) on your hard drive. Than use a dedicated burning app, like Nero, to do the actual burn.
Vince
