Activity Forums Adobe After Effects Expressions How to rotate an object around a null while keeping a static orientation.
  • How to rotate an object around a null while keeping a static orientation.
    Posted by Eric Darnell on October 11, 2011 at 9:08 pm
    I want to achieve a similar effect to the one found at 1:20 of this video. https://youtu.be/DSlY74J6iH8
    The text is rotating on a circular path and its orientation stays static. I other words the text stays upright while following a path or while attached to a rotating null. I want to create a heads up display with the same type of effect.
    Thanks for any insight that you can spare.
    cheers.
    Eric Darnell replied 14 years, 10 months ago 2 Members · 3 Replies
  • Dan Ebberts
    October 11, 2011 at 9:41 pm
    Put a null at the center of the circle, position the text layer and make it a child of the null, and give the text layer this rotation expression:
    -parent.transform.rotation
    Dan
  • Eric Darnell
    October 11, 2011 at 9:58 pm
    Thanks for the insight. In what part of the text layer do I copy the expression to?
    cheers.
  • Eric Darnell
    October 11, 2011 at 10:00 pm
    I got it! Thanks for your help.
    cheers.
