Activity Forums Adobe After Effects How to rotate a mask shape without alter its scale?
  • How to rotate a mask shape without alter its scale?
    Posted by Fonte Boa on March 6, 2006 at 10:35 pm
    AE 6.5, under WindowsXP.
    The problem come up when i created a circular mask to use as path at Render/Audio Spectrum effect. I wanted to animate the mask rotation. I set a keyframe at Mask/Mask Shape and rotated the shape (by Ctrl+T)(free transform mask) to create another keyframe some seconds after the first one. The mask rotated, but its scale varied: it scaled down and then scaled up to the original aspect. How can i avoid it?
    ps: it is not necessary to apply any effect to see the problem: if you animate the mask shape rotation, the scale will be animated too…
    Ryan Hill replied 20 years, 6 months ago 4 Members · 5 Replies
  • Ryan Hill
    March 6, 2006 at 11:19 pm
    Put the mask on another layer, rotate the layer, use it as an alpha channel track matte.
  • Steve Roberts
    March 7, 2006 at 12:32 pm
    Yep, that’s the solution.
    The explanation for that behaviour is that mask vertices travel in straight lines between keyframes. Take a look at a rotated mask and you will see.
  • Fonte Boa
    March 7, 2006 at 5:48 pm
    RobotHero and Steve Roberts : thanks for the attention.
  • Rhett Robinson
    March 7, 2006 at 10:44 pm
    We went back and forth about this on the forum yesterday, and there is a “smart interpolate” for masks that keep them from following a linear tween. I really think the track matte solution is the best for most things, but it did remind me of a feature that I’ve never used in AE, and had some pretty interesting results that were nice and smooth, bezier like flows on the masks when I played with it.
  • Ryan Hill
    March 8, 2006 at 5:13 pm
    I’ll have to check that out, and see just how smart and interpolate can be.
