Activity Forums Apple Final Cut Pro how to rotate a clip with Ken Burns effect ?
  • how to rotate a clip with Ken Burns effect ?
    Posted by Cybil Lake on March 27, 2019 at 12:07 am
    I rotated a clip using transform. Now, I want to use the ken burns effect to go move from left to right horizontally but the effect only seems to move vertically – as if I didn’t rotate the clip initially.
    Thanks for any help!
    Cybil Lake replied 7 years, 5 months ago 3 Members · 5 Replies
  • Jeff Kirkland
    March 27, 2019 at 1:34 am
    have you tried putting the rotated clip inside a compound clip and then applying the Ken Burns effect to the compound clip?
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Cybil Lake
    March 27, 2019 at 8:54 pm
    thank you – no I didn’t try that.
    is making a compound clip relatively easy?
    thank u!
  • Greg Ball
    March 28, 2019 at 9:44 pm
    Yes just right click on the combination of clips you want to use and select Compound clip from the options.
    Simple
    Greg Ball, President
    Ball Media Innovations, Inc.
    https://www.ballmediainnovations.com
  • Cybil Lake
    March 31, 2019 at 10:53 pm
    thank you I will try that! 😉
  • Cybil Lake
    April 1, 2019 at 6:44 pm
    thank you – it worked! 😉
