Activity Forums Adobe Premiere Pro How to reverse keyframes?
  • How to reverse keyframes?
    Posted by Pavel Drahoňovsky on June 27, 2021 at 1:04 am
    <div>Hello,</div>
    From template I aplied glitch effect.
    But I need the effect to work the other way around: Before the effect, the video must be “normal”, after the effect it must be “damaged” (glitch applied). Now the opposite is true.
    How to effectively turn keyframes?
    I tried to apply glitch to Adjustment layer. However, the Reverse Speed option is not available. Thank you for your answer.
    Eric Santiago replied 5 years, 2 months ago 2 Members · 1 Reply
