Activity Forums VEGAS Pro How to restrict transition FX (flash) to one track?
  • How to restrict transition FX (flash) to one track?
    Posted by Nathan Parrish on March 11, 2010 at 12:23 am
    Hi! I’m new here, and relatively new to Sony Vegas. I’ve been trying to figure this thing out, and you guys seemed helpful to someone else’s question so I thought I’d see if you could help me out as well!
    What I’m trying to do is use a transition effect on text, and not have it appear past a certain extent (geographically on the screen). I’m trying to create a help video, with screen capture video on the bottom layer, a caption bubble (static image) as the second layer, and text on top of the caption bubble. Whenever the text changes, I want there to be some sort of transition effect, to make it more difficult for the viewer to miss out on the fact that the text changed. However, I don’t want the effect to make anything happen outside of the caption box. I hope that makes sense.
    So, what I’ve done is used the “track motion” button on the text track to size it and place it such that it coincides with the caption box. However, this doesn’t appear to keep transitions from moving beyond the layers boundary, and thus far I haven’t been able to figure out how to do so.
    Here’s what I see in the middle of a transition between two events in the text layer:
    Am I going about this completely wrong? Thanks for any help!
    Mark Greenwood replied 16 years, 5 months ago 3 Members · 3 Replies
  • Roger Bansemer
    March 11, 2010 at 3:41 am
    Good question and I’d like to know but I guess if I were stuck doing something like this I’d do a transition on the box instead of the type. For instance put a quick “flash” transition on the box between text changes instead of the text itself.
  • Mark Greenwood
    March 11, 2010 at 11:56 pm
    I just tried this and you can do it by putting the transition on the TEXT layer;-
    here is what I did
    1.) Create the Vid layer, the box layer and then the text layer
    Vid Track =3, Box Track = 2, Text Track =1
    2.) Add a WHITE BORDER (or some color) around the TEXT layer
    3.) Using track motion on the TEXT LAYER scale the text layer till the border fits on top of the box layer
    4.) Now edit the text accordingly – as the scale factor may have affected how the original text looks
    5.) Now add the transition to the text layer (e.g. Hard Flash) and remove the border FX
    6.) Run it….
    6.) Transition should be limited to the contained text area now
  • Mark Greenwood
    March 12, 2010 at 12:11 am
    ….hmm then again when you have a long thin box like yours – the text looks AWFUL!!
    So I would probably go with Roger’s idea of flashing the box rather than the text,
    Maybe 9.0D or 10 will have a limit transition boundary box 🙂
    We can only hope…..
