Activity Forums Apple OS X How to restrict a folder in MAC OS X?
  • How to restrict a folder in MAC OS X?
    Posted by Marcio Oliveira on June 1, 2005 at 2:16 pm
    I have two HDs and I want to protect the files of the second one. I created some permissions and everything looks good. No other user can access my folder. The problem is – THEY CAN DELETE IT. This behavior is very wierd. How can I protect the folder from being deleted by other users?
    Do I need to change the permissions of the trash or the second HD?
    BTW my OS and all my users are in the first HD.
    Curtis Thompson replied 21 years, 3 months ago 4 Members · 5 Replies
  • Mark Sloan
    June 2, 2005 at 11:12 pm
    What version of OS X are you using?
  • Marcio Oliveira
    June 4, 2005 at 2:52 pm
    I
  • Mitchji
    June 4, 2005 at 5:47 pm
    File permissions look like this (root-owner-group):
    -rw-r–r–
    -rwxr–r–
    drw-r–r–
    d is a directory, r is read, w is write, x is execute.
    So if you want to protect a file from reading you remove the group r
    So if you want to protect a file from writing or deletion you remove the group w
    For directories if you want the directory not to be able to be deleted you remove the group w
    I think that would also protect the files inside the directory but I’m not sure.
    I think removing the r would mean that others could not view the contents of the directory
    You can change the permissions with chmod (man chmod for help)
    Best Wishes,
    Mitch
  • Marcio Oliveira
    June 7, 2005 at 6:57 pm
    Hi Mitch, thanks for answering my question. But i got to tell you: I didn’t understand. I don’t know how and where I should put these commands in. I know I’m asking too much, but can you give me a real example? Let’s say I have this folder named “test” in the desktop of my second HD called “HD02”. The user I’m working on is “Me”. How do I use these commands (r-t-w-d-x) to restrict this folder from being deleted by other users?
    Is chmod the only way?
    Please, if you could help me again, I would really appreciate.
    Thanks in advance.
  • Curtis Thompson
    June 7, 2005 at 7:11 pm
    hello…
    not to jump in on mitch’s thread, but you can do the chmod from the terminal – however, you can also ctrl-click (or right-click if you have a 2 button mouse) on the folder, select “get info” and control the permissions that way as well…
    sitruc
