How to Restore Video Track
Posted by Roger Crunden on June 10, 2020 at 10:36 pmVegas Pro 12
Two accidents whilst editing on the timeline. The first was that the video suddenly split into two – a and b. In trying to put that right hovering over the controls on the left of the page I accidentally deleted the whole video track on the time line, leaving just the audio. The main question is Can I get the video track back as it was with my edits in tact to match the audio?
Roger
Roger Crunden replied 6 years, 3 months ago 4 Members · 7 Replies -
Christian Wheel
June 11, 2020 at 3:47 amEasiest thing to do to correct mistakes like this is to Undo (Ctrl+Z) right after you make them. In the situation you find yourself in, two Ctrl+Z’s would do the trick. Unfortunately this doesn’t work if you have since closed and saved the program.
In that case, what I would probably do is delete the B clip that was created when you split, then zoom out and drag the A clip until it reaches the end, thus restoring it to its original length.
If you made multiple edits to the alignment of the audio and video prior to deleting the video track, and have since closed the project (preventing undo), then there’s not much you can do other than redo the work by dragging the video track in from scratch, ungrouping & deleting the audio that comes with it, then line it up to your audio edits.
—– Christian Wheel —–
Radio Host, Los Angeles/San Diego/Nationally Syndicated
Audio Production & Imaging
MS Visual Studio Developer
After Effects Enthusiast -
Graham Bernard
June 11, 2020 at 5:53 am[Roger Crunden] “Two accidents whilst editing on the timeline. The first was that the video suddenly split into two – a and b. “
Hi Roger! Does your Timeline look like this?
* Grazie
PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
Cameras: Canon XF300 + PowerShot SX60HS Bridge -
Roger Crunden
June 11, 2020 at 8:34 amThank you for your response but very disappointing as it seems I’ve wasted a number of pains-taking hours working on multiple small clips of a 3 hour footage program which I had reduced to two hours. I was almost half way through the whole so I suppose I’m fortunate in that I hadn’t reached the end.
Incidentally I did try the control and Z at the time but it had no effect – possibly locked by the trouble I was having with the split video tracks where the control and z had not worked on that either. Concerning the split video A and B, there was a red end to one of the clips.
I have a small amount of involuntary movement in my hands and that is the cause of my mistakes.
Roger
Roger Crunden
June 11, 2020 at 8:53 amThank you for your response.
The video clips were not separated – there was a string on A and a string on B. The two lines were broken at the point where I was moving a clip to the other side of the adjoining clip when suddenly the A and B were created. ‘Control and Z’ did not correct the situation. The end of the break was highlighted in red.
Please see my other reply on the question of the lost video track.
Roger
Roger Crunden
June 12, 2020 at 10:35 pmWell I don’t know whether I’m fooling myself but I think I’ve rediscovered my deleted video in something I’ve always disregarded cos I didn’t know what it was for. I’m referring to the BAK file and it all seems to be there with my edits.
Can someone tell me if there will be a problem with this and how I should go forward – do I need to change it to a veg file or can I continue as if it were a veg file? Should I now delete the spoilt veg file?
In essence can I carry on editing in the BAK file without worry or do I need to do something?
Many thanks
Roger
Edward Troxel
June 16, 2020 at 7:24 pm
