Activity Forums Maxon Cinema 4D How to restore c4d Object Manager
  • How to restore c4d Object Manager
    Posted by Michael Banjoko on May 12, 2009 at 11:20 pm
    Hello,
    In the course of working, i mistakenly clicked on something and my object manager has lost the standard C4D listing of objects. It’s now just a blank. Please how do i get the standard layout back? How do i send a screen shot if that will help?
    Michael
    Josh Dekay replied 11 years, 5 months ago 8 Members · 11 Replies
  • 11 Replies
  • Brian Jones
    May 12, 2009 at 11:43 pm
    Just select any layout (even the one you were using) with the top leftside button or in the Window/Layout menu
  • Michael Banjoko
    May 13, 2009 at 8:26 am
    Hello,
    I’ve done that and the object manager is back in place but it’s still appears blank, not showing the typical listing of all my objects, as they would appear, for example, in the timeline.
    Michael
  • Larry Blackbox
    May 13, 2009 at 1:38 pm
    Perhaps you clicked “new Project” and you have a blank object manager
    if so look under the window menu to see if any pre existing project is open already. Just a thought
    Good Luck
  • Michael Banjoko
    May 13, 2009 at 2:58 pm
    Hello,
    Please bear with me. Can you be a bit more explicit regarding how to, according to your comment, ‘select any layout’?
    Michael
  • Michael Banjoko
    May 13, 2009 at 3:20 pm
    What i basically need is to see my objects listed in the currently blank object manager as they appear in the timeline window.
  • Adam Trachtenberg
    May 13, 2009 at 4:14 pm
    It sound like you may have turned on filters for the Object Manager. Click the eye icon at the top-right of the OM and make sure that eye icons inside are all turned on.
  • Michael Banjoko
    May 13, 2009 at 8:51 pm
    Hello and,
    Phew! Finally got it sorted. In the object manager, i did View>Goto Main level and my listings came back. Many many thanks for the support.
    Regards
  • Doug Hadfield
    February 21, 2014 at 5:50 pm
    Thanks, I had the same problem! Weird setting… I hit it with it’s short key!
  • Tim Pfeiffer
    September 26, 2014 at 3:14 pm
    I hit something in the view section in the Object Manager and now no objects show up. I’ve tried changing all the different view settings and everything I can think of to restore the Object Manager. I have an empty object manager. Even in I make a simple cube it doesn’t show up in the Object Manager. I need some help!
  • Ian Johnson
    November 4, 2014 at 11:04 pm
    Check that you haven’t searched for something that gave no results and then hidden the Search Bar.
    I just did this and was struggling to figure out why I couldn’t see anything in my Object Manager.
    Note: This stays with the saved file, so saving and restarting did not help.
