Activity › Forums › Avid Media Composer › how to resize to small a High Res image
Posted by Blitooth on June 17, 2007 at 11:25 amHi!I
Grinner Hester replied 18 years, 11 months ago 4 Members · 3 Replies -
Michael Phillips
June 17, 2007 at 2:25 pmUse the Pan and Zoom function. See Use Manual on its use.
Michael
anything 24fps
Terence Curren
June 17, 2007 at 2:30 pmOr better yet, use Avid FX (boris FX) which came free with your system if it’s newer or Moving Picture (www.stagetools.com).
Pan & Zoom will cause problems if your picture is too large, and it doesn’t allow you to rotate your picture.
Terence Curren
http://www.alphadogs.tv
http://www.digitalservicestation.com
Burbank,Ca -
Grinner Hester
June 17, 2007 at 4:50 pmselct resize in your import settings. This’ll give you the entire image and you can then use a pip effect to do what you like with it. You just can’t zoom in past 100% much this way as it’ll start tearing it up.
