Activity Forums Adobe After Effects Expressions How to resize an existing shape layer using Scripts?
  • How to resize an existing shape layer using Scripts?
    Posted by Amrithnath Vijayakumar on October 23, 2018 at 5:25 am
    Hey,
    I’m pretty new to scripting in After Effects and After Effects in general. I am currently trying to create a video template that can be used for multiple projects using scripts and some data from the clients. Basically these videos would be similar to infographs , I’m trying to scale a shape layer based on a percentage value from the data file, so far i’m unable to access the transform property of the shape layer. Any help would be appreciated.
    Thanks ????
    Amrithnath Vijayakumar replied 7 years, 11 months ago 2 Members · 2 Replies
  • Steve Sierra
    October 23, 2018 at 8:20 am
    You should check out redefinery.com, he has a free script called prop path I think which will give you the path to any property in any type of scripting/expression language !
    His tutorials are great too ????
    https://www.redefinery.com/ae/rd_scripts/
    Cheers !
  • Amrithnath Vijayakumar
    October 23, 2018 at 9:31 am
    Hey thanks a ton , that really helped me. I will go through the tuts as well , thanks for the info ????
