Activity Forums Apple Final Cut Pro how to reset zoom adjustments
  • how to reset zoom adjustments
    Posted by Roger Sherman on November 2, 2020 at 1:45 pm
    I had some mic in shot issues, so I zoomed in to remove them while I was cutting. Now that the film is finished and am about to do color correct, I want to remove the adjustments, so the colorist can correct in Resolve.
    How do I find those shots to remove the zoom?
    thanks
    David Battistella replied 5 years, 10 months ago 2 Members · 1 Reply
  • David Battistella
    November 2, 2020 at 3:12 pm
    You can select all of the shots in the timeline and go to the transform tab in the inspector window and at the top right corner is the reset button.
    that will reset every shot in the timeline that has any transform on it.
    Or you could select the shots you want to reset and do the same thing.
    Duplicate or use the snapshot feature before you do this. Also, it is not a huge step for the colorist to do this just after import.
    David
