Activity Forums Adobe After Effects How to reset the timeline tabs order
  • How to reset the timeline tabs order
    Posted by Evan Robinson on August 6, 2012 at 7:16 pm
    Hi all,
    See the order the panels are in this picture? The mode panel source name and trkmte
    How do reset them to default order?
    Evan Robinson replied 14 years ago 3 Members · 3 Replies
  • Dan Fredley
    August 6, 2012 at 7:36 pm
    You can trash your preferences, but I would just grab the top of the “Mode” panel and drag it to the right of the “Switches” Panel. You can drag any of them around and right-click to hide or show panels. You can also drag in between the panels to change the widths–for example, the labels panel can shrink down to hide the color text.
  • Vishesh Arora
    August 6, 2012 at 7:42 pm
    May be you can try to delete your Prefs file.
    C:Documents and SettingsYour User NameApplication DataAdobeAfter Effectsversion(say 10) on XP and On other operating systems the path is different, but the procedure is the same. Delete After Effects Prefs.txt and you will get all your setting revert to original.
    I am a keen learner and am very keen on pursuing a career in the animation industry. My artistic skills are mostly self-
    taught. I have a deep knowledge base of Photoshop, Maya, Adobe Premiere, After Effects, Final Cut Pro and Sony Vegas.
  • Evan Robinson
    August 6, 2012 at 8:36 pm
