Activity Forums Adobe After Effects Expressions How to replace string to source text in script??
  • How to replace string to source text in script??
    Posted by Adrián Wulfrath on April 8, 2016 at 5:17 pm
    Hi, i actually have this script but i dont know how to change what i put inside my string and change my source text
    Here is my code, and when i press the button change the text.
    //AQUÍ EMPIEZA A CREARSE LA VENTANA DEL PANEL
    function myScript(thisObj){
    function myScript_buildUI(thisObj){
    var myPanel = (thisObj instanceof Panel) ? thisObj : new Window("palette","Panel Estudio Voraz",undefined,{resizable:true});
    res = "group{orientation:'column',\
    groupOne: Panel{text:'Master', orientation:'column',alignment:['fill','fill'],alignChildren:['fill','fill'],\
    txtWrite: EditText{text:''},\
    txtBtn: Button{text:'Press'},\
    myPanel.grp = myPanel.add(res);
    var Btn = myPanel.grp.groupOne.txtBtn
    var a = "hola"
    var bstr = myPanel.grp.groupOne.txtWrite.text
    Btn.onClick = function()
    //END PANEL --------------------------- NO PONER NADA ABAJO DE ESTA LÍNEA -------------------------------
    return myPanel;
    var myScriptPal = myScript_buildUI(thisObj);
    if((myScriptPal != null) && (myScriptPal instanceof Window)){
    myScriptPal.center();
    myScriptPal.show();
    myScript(this);
    Adrián Wulfrath replied 10 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
