Activity Forums Adobe After Effects Expressions How to replace one line of code in multiple layers?!
  • How to replace one line of code in multiple layers?!
    Posted by Greta Senne on April 18, 2018 at 1:42 pm
    Hey everyone,
    is there a way to exchange for example one word in my expression with another but in multiple layers? i have a little (tiny tiny) bit of experience in coding and when i used “sublime” i could look for the same word in a hole file an change them all together.
    i hope you get what i tried to explain.
    Greta Senne replied 8 years, 4 months ago 3 Members · 3 Replies
  • Scott Mcgee
    April 19, 2018 at 9:42 am
    I create a expression control comp and keep all my expression layers in there and tie them us using something like this to the multiple layers
    eval(comp(“1 – Control Center”).layer(“City”).text.sourceText.toString())
    then if I need to make any changes I go to my expression control comp and make the alterations there, once updated. this updates all the layers it’s need for.
    Hope that helps
  • James Ronan
    April 19, 2018 at 12:19 pm
    This sounded quite like an interesting task so thought I’d give it ago. Bit rough, and haven’t done a lot of testing but it should replace every instance of that word, project wide.
    Make sure the value for the oldWord variable has ‘/’ and ‘/g’ before and after it so that it doesn’t only change the first instance of the word per expression.
    var oldWord = /old/g;
    var newWord = "new";
    app.beginUndoGroup("Expression Swap");
    for (var a = 1; a <= app.project.numItems; a++) {
    if (app.project.item(a) instanceof CompItem) {
    for (var b = 1; b <= app.project.item(a).layers.length; b++) {
    scanPropGroupProperties(app.project.item(a).layer(b));
    } // end of layer loop
    } // end of check if comp item
    } // end of comp loop
    app.endUndoGroup();
    function scanPropGroupProperties(propGroup) {
    var c, prop;
    // Iterate over the specified property group's properties
    for (c = 1; c <= propGroup.numProperties; c++) {
    prop = propGroup.property(c);
    if (prop.propertyType === PropertyType.PROPERTY) // Found a property
    expressionFix(prop);
    } else if ((prop.propertyType === PropertyType.INDEXED_GROUP) || (prop.propertyType === PropertyType.NAMED_GROUP)) {
    // Found an indexed or named group, so check its nested properties
    scanPropGroupProperties(prop);
    function expressionFix(prop) {
    if (prop.canSetExpression === true) {
    if (prop.expressionEnabled === true) {
    var curExp = prop.expression;
    curExp = curExp.replace(oldWord, newWord);
    prop.expression = curExp // updates old expression with new words
    I used the recursive property function from redefinery to loop through the properties: https://www.redefinery.com/ae/fundamentals/properties/
  • Greta Senne
    April 19, 2018 at 2:47 pm
    Thank you very much! I currently have no time today to try out both of your ways – but i cant wait!
    i´ll let you know if i was successfull
