Activity Forums Adobe After Effects How to replace image while maintaining keyframes
  • How to replace image while maintaining keyframes
    Posted by Dragos on April 15, 2010 at 8:11 pm
    Sorry if this is a noob question. I know how to do this in Apple Motion, but I’ve recently started working with After Effects again.
    Basically I’ve created a little bumper that has images animate into the frame. I wanted to see if there was an easy way to take a new image and replace the current image while maintaining the position, animation, and applied effects. I know I can copy and paste the keyframes, but I would like to maintain the effects settings without having to apply them to each element over and over again.
    Is there a way to do this? In motion you simply drag your new asset on top of the old asset and it will replace it, but I don’t know how you do this in AE.
    Thanks.
    Logan Drayson replied 12 years, 11 months ago 3 Members · 2 Replies
  • Dave Johnson
    April 15, 2010 at 8:19 pm
    If the item you want to replace it with is already in your project, select the layer you want to replace and hold Option while you drag the new item over the layer to be replaced in the timeline.
    If not, right click the item in the project window and choose Replace Footage.
  • Logan Drayson
    October 23, 2013 at 6:52 am
    Hello, I’m currently working for a real estate company that uses Sony Vegas… They use a program called Sony Production Assistant 2.0 to automate their Vegas templates.
    In Vegas they have empty slugs and with the assistant program they pick their 25 images and pick the template and the assistant automatically populates those empty slugs with the 25 images. My boss wants me to do this same thing but with AE. I know if you open a AE file and option drag a file on a layer it will replace it. But is there a way to automate this with AE.
    Thank you,
