Activity › Forums › DaVinci Resolve › How to replace conformed media with full lenght originals
  • How to replace conformed media with full lenght originals
    Posted by Kaspar Kallas on September 7, 2012 at 11:30 am
    Hello
    I started a project way back when and I was given a FCP project with media managed media. Now I got final cut of the project but this one is with full media.
    Is there any way to replace the media on the version that I was working on to the full media and then add a another cut to retain my work?
    It is documentary project where I use many versions on single clip because of cuts so colortarce will not work because it will copy only one version…
    Thank You
    Kaspar
    Sascha Haber replied 14 years ago 2 Members · 3 Replies
  • Sascha Haber
    September 7, 2012 at 12:04 pm
    So you got consolidated movie files with timecode and reel ID intact ?
    And now you got full clips ?
    Then it should be easy.
    If you one the other hand got total different media you should call the post producer and unleash hell 😉
    Color Trace would be my next attempt , if that fails use the Create Thumbnail from Middle Frame and do it manually from a freshly created Gallery page.
    A slice of color…
    DaVinci 9b3 OSX 10.8
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / Quadro 4000
    Extreme 3D+
    Colorist / Aerial footage nerd
    https://vimeo.com/saschahaber
  • Kaspar Kallas
    September 7, 2012 at 12:11 pm
    Hi
    It seems version A (well there are no reel ID’s but I should be able to do it by folders at minimum) but I don’t know if the media is same names. Anyhow I will start to play with this tonight and will post my findings for anyone else that might find it helpful.
    I think that colortrace could copy over all remote versions, that would be “muy” helpful.
    Thank You
    Kaspar
  • Sascha Haber
    September 7, 2012 at 1:08 pm
    I muy muy agree 🙂
    A slice of color…
    RAID0 8TB
    Extreme 3D+
