Activity Forums Adobe Premiere Pro How to replace Clips in Timeline Without effecting its effects and transition?
  • How to replace Clips in Timeline Without effecting its effects and transition?
    Posted by Mohamed Bilal on June 29, 2008 at 1:42 pm
    How to replace Clips in Timeline Without effecting its effects and transition? eg: if a clip in time line splitted to two and inserted a transition between them and also changed the first clip’s speed to 50% and also added a motion blur to the first clip.If we need to change the first clip to another clip without affecting its speed and Blur filter and its speed, what we can do?Please help me…Thanks alot…
    We humans all are One
    Mohamed Bilal replied 18 years, 2 months ago 3 Members · 3 Replies
  • Terry Kampowski
    June 29, 2008 at 1:59 pm
    Another way to do what you want is to “Copy” your effects. Then when you put in the new clip, just “paste” the effects on it.
  • Jon Barrie
    June 29, 2008 at 11:17 pm
    This only works in CS3!
    If you want to replace a clip in the timeline while keeping the effects,transitions etc you can do this several ways.
    1a. Clip for clip – Select the clip in the Project Panel, hold the ALT key, drag it ontop of the clip you want to replace in the timeline, when it highlights over the top let the mouse go (HOLD ALT STILL).
    1b. Clip for clip – Select clip in project panel. Right click the clip in timeline. select replace>bin.
    2. Frame Match – Open the clip you want to replace with in the source monitor. move the playhead to the frame you want to match in replacement. Find the matching frame in the timeline clip. Right click and replace>from source monitor, match frame.
    – Jon 😉
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
  • Mohamed Bilal
    June 30, 2008 at 4:00 am
    Thanks alot friends for ur valuable support…
