Forums Adobe After Effects Expressions How to repeat a frame if the following frame is too bright.
  • How to repeat a frame if the following frame is too bright.
  • tilghman wendel
    June 2, 2021 at 7:30 pm
    First post and a longtime fan of this community.
    In an attempt to thwart photosensitive seizures caused by strobing media, I’m trying to build some AE expressions that will repeat/duplicate the “safe” frame in place of the “dangerous” frame that suddenly rises in luminescence.
    i.e IF frame 23 is this much brighter than frame 22, THEN hold frame 22 for an extra frame.
    Thus, I came across some brilliant code to analyze the brightness of the frame.
    sampleLayer = effect(“Layer Control”)(“Layer”)
    color = sampleLayer.sampleImage([sampleLayer.width/2, sampleLayer.height/2], [sampleLayer.width/2, sampleLayer.height/2]);
    brightness = Math.sqrt(0.299*color[0]*color[0] + 0.587*color[1]*color[1] + 0.114*color[2]*color[2]);
    This successfully spits out a brightness value between 0-1. The next step is to tell After Effects “IF the next frame has a rise of .2 in brightness, THEN hold the current frame for one frame. This is where I got stuck.
    Thank you kindly for any help.
  • Dan Ebberts
    June 2, 2021 at 10:03 pm
    Assuming that the layer in question is time remapped, then a time remapping expression like this might mask single-frame brightness bursts:
    sampleLayer = thisLayer;
    cNow = sampleLayer.sampleImage([sampleLayer.width/2, sampleLayer.height/2], [sampleLayer.width/2, sampleLayer.height/2]);
    brightnessNow = Math.sqrt(0.299*cNow[0]*cNow[0] + 0.587*cNow[1]*cNow[1] + 0.114*cNow[2]*cNow[2]);
    cPrev = sampleLayer.sampleImage([sampleLayer.width/2, sampleLayer.height/2], [sampleLayer.width/2, sampleLayer.height/2],true,time-thisComp.frameDuration);
    brightnessPrev = Math.sqrt(0.299*cPrev[0]*cPrev[0] + 0.587*cPrev[1]*cPrev[1] + 0.114*cPrev[2]*cPrev[2]);
    if (brightnessNow - brightnessPrev > .2)
    time - thisComp.frameDuration
    else
    time
Viewing 1 - 2 of 2 posts
Log in to reply.
