Activity Forums Adobe After Effects How to render in the background.
  • How to render in the background.
    Posted by Jerry Smith on June 17, 2016 at 1:59 pm
    I want to be able to render things in the background and continue to work in AE. Evidently, I need more than AE and Media Encoder to do this. It seems to say I need Dynamic Link installed. So does that mean I have to install Premier Pro?
    Walter Soyka replied 10 years, 2 months ago 4 Members · 12 Replies
  • 12 Replies
  • Michael Szalapski
    June 17, 2016 at 2:18 pm
    What is the exact text of your error message?
    What steps are you taking to get that error message?
    What exact version (down to the build number) of After Effects are you using?
    What exact version (down to the build number) of Adobe Media Encoder are you using?
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Jerry Smith
    June 17, 2016 at 2:36 pm
    Could Not Connect To Adobe After Effects. Please Verify That Adobe After Effects & Adobe Dynamic Link components are installed.
    I get that when I go to the menu item to encode an AE project.
    I use 13.2.0.49 AE and most current Media Encoder.
    I don’t have Premier installed because I haven’t needed it. I have the subscription, but my machine whispered that it would appreciate it if I could not install any more stuff.
  • Jerry Smith
    June 17, 2016 at 2:39 pm
    Sorry, wrong message
  • Jerry Smith
    Not sorry. That was the message. Sorry, vicious multitasking.
  • Michael Szalapski
    June 17, 2016 at 2:50 pm
    [Jerry Smith] “I use 13.2.0.49 AE and most current Media Encoder.”
    This is likely the issue. You need to have matching versions. 13.2.0.49 is not the latest version of After Effects. Either use the older version of Adobe Media Encoder or use the latest version of AE which is 13.7.1 on Windows 13.7.2 on Mac
    As a heads-up:
    For the past three years, Adobe has released a new version of After Effects, AME, Premiere, etc. towards the end of June. So, if this year is the same, the “latest” version number of AE I just said, is likely to become an old version in a week or two.
    Anyway, what I said holds true for now. 🙂
    – The Great Szalam
  • Jerry Smith
    June 17, 2016 at 2:53 pm
    I can’t upgrade AE. It would be an act of total insanity. Is there someplace I can get the older version of ME?
  • Michael Szalapski
    June 17, 2016 at 3:02 pm
    You should totally try CC 2015. It’s not an “upgrade”. You can have them installed alongside each other. In fact, it’s recommended. See this page [link]
    Since the most recent updates to CC 2015, it’s worked pretty well for me on both Mac and Windows. I don’t even open up CC 2014 anymore except (maybe) to render with multiprocessing.
    The new version of AE that is releasing “soon” (historically in the next two weeks as I said), is supposed to be even better. A more stable preview, GPU acceleration of some effects, some expressions enhancements, etc.
    The buzz I’ve heard is quite good!
    The good thing about installing CC 2015 is that you can open project files created in either version of AE in either version of AE. They’re both version 13.x of AE, so you can use project files interchangeably between them. So, if you don’t like CC 2015, you can just jump back to CC 2014 to keep working.
    You should have the older version of AME installed when you installed After Effects, but if it got updated, the CC app sometimes likes to remove the older versions. (Make sure you uncheck the box to remove older versions when/if you install CC 2015 or the new version when it comes out). If you install Premiere Pro CC 2014, it should install AME CC 2014 along with it. This page covers installing old versions [link].
    – The Great Szalam
  • Jerry Smith
    June 17, 2016 at 3:12 pm
    Thanks Michael. I have a newer version on another computer that I mess around with and I like it. But I won’t risk it with the real stuff. I’ll try an older version of ME.
  • Jerry Smith
    June 17, 2016 at 3:43 pm
    OK, I got the older version of ME running, but when navigate and click on the project, it’s only showing me one of the compositions and one or two folders. There should be a couple dozen compositions and a dozen folders. 🙁
  • Jerry Smith
    June 17, 2016 at 3:45 pm
    I can’t open the folder, and the one project it links to is a minimal project that just has a couple of AI files inside.
