Activity Forums Avid Media Composer How to render in After Effects for Avid Express Pro
  • How to render in After Effects for Avid Express Pro
    Posted by Coverbee on August 22, 2006 at 11:56 pm
    Hi there
    Here’s my question
    I’m working on a mac G5 on a project in After Effects 6.5
    When it’s done I have to make a file that contains an alpha Channel (if possible) which will open without problem in Avid Express pro( if possible)
    By the way the Avid Express NLE is running on Windows XP.
    I’ve read much about this subject but I’m still confused..there seem to be several options
    What render cq Import settings are the best for this job. What codec should I choose.
    Hope to hear from you
    Thanks in advance
    Cheers
    Coverbee replied 20 years, 1 month ago 3 Members · 4 Replies
  • Satesh Ramjattan
    August 23, 2006 at 2:29 am
    the QT “animation” codec gives you the option of exporting with an alpha channel.
  • Michael Hancock
    August 23, 2006 at 2:42 am
    You can use the animation codec, which is lossless. Render in the correct field order so you don’t get jitters, and if you want to bring an alpha into the Avid set it to million of colors+ with a straight alpha. When you import into your Avid, select the same field order you rendered it out of and invert existing alpha.
    For a faster import, visit the Avid website and download the Avid codecs. Will decrease your file format conversion time dramatically. If you use an Avid codec, use Use Existing Alpha when you import it into your Avid.
    If you run into problems post back here and we’ll walk you through it.
    Mike.
  • Coverbee
    August 23, 2006 at 8:38 am
    Thanks very much sdragon and Promoboy for advice.
    If problems occur in a few days you will hear from me again
    thanks again
  • Coverbee
    August 23, 2006 at 7:28 pm
    Hi there
    I’m still not sure what to do, please advice.
    I made some textgraphic in Photoshop CS, sqare pixels and all.
    Then I imported the layers into After Effect 6.5 as a comp.I animated it and added a few effects. nothing to hot I think just a lightsweep effect, some level adjustment, some fastblur etc.
    All the composition I made in AE where square pixels.
    I rendered my final comp using animation codec, millions of clors +, rgb plus straight alpha, field rendering even lowerfield first.
    Just to check things I import the quicktime render into Avid Free DV. Importsettings : Maintain, square; RGB;
    Invert existing alpha; Even (lowerfield first.
    Somehow it looks a bit funny. wht little red dots wher is supposed to be transparency. It looks a bit like opening a QT with alpha in the quicktime player, since it is not capable of ‘showing’ an alpha channel.
    I’m not sure at what stage things go wrong….
    Is Avid Free DV capable of handeling an Alpha channel or not
    I’ll be glad to hear from you again.
    Best regards
    btw. I’m working on an Apple G5. PAL format.
