Activity › Forums › Maxon Cinema 4D › How to render an object buffer of hollow space?
  • How to render an object buffer of hollow space?
    Posted by Craig Ricker on May 29, 2012 at 4:05 am
    Ok there is probably a very simple solution to this:
    But I have made a gas chamber frame and would like to render out an object buffer of all the inbetween bits of the frame. So basically, where the gas will be.
    I made a rectanglur model that fits inside the chamber perfectly and applied an object buffer to that, but if I turn it off so you can see the inside edges of the gas chamber, the object buffer doesnt render out.
    Is the only option to run the render a second time with the cube in, and do the luma matting later in after effects. Basically I just wanted to do 1 render rather than 2?
    Any thoughts.
    Elin Grome replied 14 years, 2 months ago 3 Members · 2 Replies
  • Adam Trachtenberg
    May 29, 2012 at 2:41 pm
    Yeah, I think you’re going to have to render twice.
  • Elin Grome
    July 13, 2012 at 3:58 pm
    i also found that rendering the object at 99% transparency can be a dirty workaround in some cases…
    It’s all the those pesky details :p
