Activity Forums Maxon Cinema 4D How to render all frames of render region only
  • How to render all frames of render region only
    Posted by Jon Simpson on October 15, 2014 at 1:05 pm
    I have a project that will take forever to render if every frame is rendered in full. So what I want to do is in After Effects, use one full frame with all objects included, then mask off and add individual render regions – instead of rendering the whole scene in every frame. In other words, I want to set a render region and only render that section for all frames. Is this possible?
    Brian Jones replied 11 years, 10 months ago 2 Members · 3 Replies
  • Brian Jones
    October 15, 2014 at 4:40 pm
    yes, there is a setting in Render Settings/Output called Render Region, activate that and it allows you to set your boundaries (or copy them from the interactive render region).
  • Jon Simpson
    October 15, 2014 at 4:58 pm
    Thanks Brian, I have tried that and it only gave me the first frame.
  • Brian Jones
    October 16, 2014 at 2:43 am
    it will render all the frames if you set the Frame Range to All Frames
