Activity › Forums › Apple Final Cut Pro Legacy › How to render a subtitle sequence on timeline
  • How to render a subtitle sequence on timeline
    Posted by George Roberson on July 28, 2014 at 4:41 am
    I finally get the subtitle on the timeline (I did change the speed since I wrote my title based on .mov file which ends up longer than FCP file – don’t know why), but it won’t let me render it. At first it started rendering, saying it is going to take a couple of hours, then the pop up window disappears, with file unrendered. When I try to render again, it just flashes.
    Thanks so much for your input.
    George
    Andreas Kiel replied 12 years, 1 month ago 3 Members · 2 Replies
  • Nick Meyers
    July 28, 2014 at 7:03 am
    you are probably running low on RAM,
    try to render the subs in smaller sections.
    nick
  • Andreas Kiel
    July 31, 2014 at 8:05 am
    George,
    Download my TitleExchange package.
    It includes an app called gRender (free).
    Export your subtitle only timeline as XML.
    Then import into gRender. The app will create a new XML, an EDL and some more files.
    Open the newly created XML in FCP and render out the sequence as image sequence (with alpha). It’s a fast action.
    Open the EDL in FCP and reconnect the images.
    Though it sounds complicated – it’s not.
    The rendered subtitles require way less memory compared to the “generator version”.
    – Andreas
    Spherico
    https://www.spherico.com/filmtools
    “He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil
