Activity › Forums › Adobe After Effects › how to Render 4608×128 mp4
  • how to Render 4608×128 mp4
    Posted by Peter Jones on February 21, 2018 at 9:50 am
    Is it possible to render a 4608×128 mp4 mp4 from AfterEffects or via Media Encoder?
    is this H265 which Media Encoder doesn’t support yet?
    The AV company won’t accept Prores codec
    – Pete
    senior editor
    Peter Jones replied 8 years, 7 months ago 2 Members · 2 Replies
  • Walter Soyka
    February 21, 2018 at 10:48 am
    4608 is wider than the H.264 standard allows, so Adobe Media Encoder will not produce this out-of-spec file.
    However, ffmpeg doens’t care and will happily produce a file with those specs. You could transcode a render with ffmpeg from the command line, or you could use render directly from Ae with AfterCodecs:
    https://aescripts.com/aftercodecs/
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Peter Jones
    February 21, 2018 at 1:03 pm
    Thanks Walter.
    Purchased the Aftercodecs plugin and works fine.
    – Pete
    senior editor
