Activity Forums VEGAS Pro How to remove these lines?
  • How to remove these lines?
    Posted by Lovro Stracak on April 11, 2009 at 8:18 am
    Hello again! So I’ve seen many people that have this problem. After rendering video is normal, but when encoded to .mp4 format, lines appear, and then it looks ugly, here is example how it looks https://www.xfire.com/video/9feab/ . Heard it has something to do with rendering options. Please help, thanks in advance.
    Lovro Stracak replied 17 years, 5 months ago 3 Members · 3 Replies
  • Theo Van laar
    April 11, 2009 at 10:14 am
    Choose ‘interpolate fields’ or ‘blend fields’ in the project properties for deinterlacing method.
    Theo
  • John Rofrano
    April 11, 2009 at 2:34 pm
    That’s correct. Those are lines caused by viewing interlaced video on a non-interlaced device. You need to render your video to progressive format if you plan to view it on a PC. Just select Field Order = None in the rendering template that you use.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Lovro Stracak
    April 11, 2009 at 2:37 pm
    Thank you both very much.
